Latest post 06-10-2007 12:04 PM by kaka. 3 replies.
Page 1 of 1 (4 items)
  • 06-10-2007 5:31 AM
    • kaka
    • Not Ranked
    • Joined on 05-13-2007
    • Posts 23
    • Silver Member
    How do I clean the glass on my BV7?
    Sorry - this one has been asked before I seem to remember, but I cannot find the thread.  Does anyone have any tips - there are tiny tiny little specks which are difficult to get off, and also normal smears from the hands of a two-year-old...
    I'm afraid of doing something wrong, so I thought I'd ask first...
    Thanks all!
  • 06-10-2007 6:31 AM In reply to
    Re: How do I clean the glass on my BV7?
    I use Windolene on my Avant. The coating is on the inside so you should not be able to damage it. A gentle glass cleaner is fine!
  • 06-10-2007 10:42 AM In reply to
    kaka:
    Thanks all!
    During the visit in struer, the guy who was looking after the production of the BV7 said "No alcohol"... or 5% max...
    You are warned!
  • 06-10-2007 12:04 PM In reply to
    • kaka
    • Not Ranked
    • Posts 23
    • Silver Member
    Thanks chaps.  I shall try (diluted) windolene.  The guy at B&O here said (helpfully) no ajax... Indifferent
