Latest post 10-19-2009 2:20 PM by Louis. 2 replies.
Page 1 of 1 (3 items)
  • 10-06-2009 1:53 PM
    • Louis
    • Not Ranked
    • Joined on 07-26-2009
    • Posts 42
    • Gold Member
    a view questions
    Hello,
    I am new here and i apologize for my English. It is not so good as i wish.
    I bought the beovision 7 with BR and a motorized stand.  I also have the configuration tool. I have a view questions.
    1.
    - I have a  Humax with BIK code and it works fine. When i change the button it still works fine.
    - I have a Netgear EVA9150 Digital entertainer. The dealer made a button called DVD2. He choose the BEO dvd2.  When i press the button, the tv is set to the EVA 9150 and i can use the remote from the Netgear. When i change the name of the button in,for example  Netgear the button does not work anymore. So i want to make a new button and i only want the tv go to the aux where the netgear is on. Howe can i do that.
    2. Does annyboddy have a template for the Netgear9150
    3. I wood like to change the stand of my tv.  Howe can i change it with the Beo5. What command i have to use.
    Thanks,
    Louis.
  • 10-19-2009 5:20 AM In reply to
    • Jan
    • Not Ranked
    • Joined on 07-15-2007
    • Netherlands,Flevoland
    • Posts 27
    Re: a view questions
    Hello Louis
    Question two is solved,i hope the Netgear xml file is working fine for you.
    About your third question: If i program the avant i get also a stand button.
    Regards
    Jan
  • 10-19-2009 2:20 PM In reply to
    • Louis
    • Not Ranked
    • Posts 42
    • Gold Member
    Tank you Jan,
    It works fine.
    Anyone for question 1?
    Louis
