Latest post 06-11-2007 3:37 PM by nickandh. 8 replies.
Page 1 of 1 (9 items)
  • 06-10-2007 5:02 AM
    BV32, STB-C and Sky+
    Hi
     I've got the above setup. I have a Thomson SKY+ box but it's not on the BV32 internal list so I have selected Pace Sky+.
    It works perfectly except that each instruction seems to be double. For example if I move on one channel in the listings page the cursor jumps 2 channels. If I enter a single digit '2' it comes up on screen as '22' etc. This renders the mechanism pretty much unusable.
    Does anyone else have similar problems, or know of a solution.
    Nick
  • 06-10-2007 6:29 AM In reply to
    Re: BV32, STB-C and Sky+
    This sounds like you have two IR eyes working. Do you have an audio set up attached by ML? All Sky+ boxes use the same code so that is not the problem.
  • 06-10-2007 6:31 AM In reply to
    • Movie
    • Top 500 Contributor
    • Joined on 04-18-2007
    • Posts 90
    Nick
    I am not sure but it may be that the BV32 is set to wrong option, or you have other B&O connected that needs to have option changed.
    Movie
  • 06-10-2007 9:42 AM In reply to
    • Top 75 Contributor
    • Joined on 04-01-2007
    • UK
    • Posts 970
    I had this when i didnt stick the I-R lead exactly in the right place on the SKY+ box. try and reposition it.
  • 06-10-2007 12:47 PM In reply to
    • Jandyt
    • Top 10 Contributor
    • Clitheroe, Lancashire, UK
    • Posts 13,004
    Yes, I think Peter is right.
    Check THIS thread.
    Andy T.
    Poor me, never win owt!
  • 06-11-2007 3:25 AM In reply to
    Spot on. I put a newspaper over the top of the connected ouverture and the problem disappears.
    It must be because I have the ouverture as option 2 and the BV32 as option 1. The thing is I find it irritating having to use AV to get the tv sound via the speakers and this set up generally works. (The speakers are connected to the ouverture, and option 0 on the TV doesn't get a video command so no picture appears, just sound - well that's my guess).
    I'll just have to live with two controllers or get a surround sound module for the tv.
    Thanks for your help.
  • 06-11-2007 4:05 AM In reply to
    Definitely get a surround module - the whole system will benefit!
  • 06-11-2007 2:53 PM In reply to
    • Jandyt
    • Posts 13,004
    Nick, How many speakers have you got plugged into your Ouverture?
    If it's just two, couldn't you just plug them into the TV, make the TV the master and put the Ouverture into option 0. That way you wouldn't have to use AV button.
    Somebody correct me please if I'm wrong.
    Andy T.
  • 06-11-2007 3:37 PM In reply to
    You'd think so, wouldn't you. Unfortunately unless I get the surround sound module there are no powerlink sockets on a BV-32!
