Probably a dumb question, if so, sorry.
Due to the geography of the lounge we needed to invest in one of these so everyone in the room can see the tele (BV4).
It comes with a remote control where you can guide the screen to the desired viewing angle (I say so myself, it's pretty damned good). I wondered if it would be possible to put these 3rd party commands on the Beo5 remote? What is the way forward? I assume I need to capture the IR signal from the Vogel remote and then copy it to the Beo5, doesn't sound too hard (famous last words!). Is there an economic way that this can be done without having to invest in another £200 worth of hardware to "listen" to my remote to decipher the codes so they can be copied across.
Sorry for being such a newbie! The rest of the B&O stuff we seem to have mastered, it's the 3rd parties we are struggling with
Cheers
Gary
http://www.youtube.com/watch?v=4eiOmnCAHmE
Format: ???
Duration: 45 seconds
