Sorry if this has been covered before, although I did search the forum and
couldn't find anything.
I have a BV7 40 MKII and just had my local dealer connect it up to a
Virgin V+ box on AV3 (he connected my Apple TV to DVI-I), for some reason
whenever I select Virgin (DTV) using my BEO5, Virgin starts up fine but then
after a few seconds it turns off. It then takes an age for it to turn on again
or I have to open the cabinet and do it manually.
Also, I have setup a number of channels on the BEO5 and the behaviour is
very random, sometimes nothing happens at all, sometimes it changes the numbers
and doesn't actually go to the channel and occasionally it actually works as
expected.
I assume it has something to do with the STB or the IR cable - I have moved
it a million times and re-taped etc but no luck.
Anybody had a similar experience and managed to resolve it? Any suggestions
gratefully received.
