Latest post 10-06-2009 2:15 PM by Beobuddy. 3 replies.
Page 1 of 1 (4 items)
  • 10-04-2009 3:46 PM
    Tweaking Beoportsoftware
    If have a pc connected to a beoport.
    When using NMusic I have openend all the info screens (left album bar, album cover and right source bar) as the pc is only used for NMusic, NRadio etc.
    But when I stop NMusic, the info screens disappears.
    Is there a  kind of tweak inside windows so when you start NMusic again, all the info screens opens again?
  • 10-04-2009 4:12 PM In reply to
    Re: Tweaking Beoportsoftware
    Not really - the application itself should be responsible for that. But do you happen to have any experience in programming? There is this scripting language called AutoHotkey, which among other uses makes it possible to "fake" anything a user would normally do on the keyboard and mouse. So you could create a script that would do all that window opening & positioning stuff for you when you simply press F12, for example.
    It's completely free and quite powerful. The downside is that the language syntax is horrible... And I can't help you with any details since I don't have Beoport myself.
    -mika
  • 10-04-2009 4:31 PM In reply to
    No, sorry, no experience in programming other than Turbo Pascal from the 80'sBig Smile
    But in windows registry  HKey_current_users and HKey_users you can find settings of Beoplayer.
    But not all settings are logical to explain. There are some, if you change them (like sound settings e.g.) you notice the difference immediately.
    So, I got a 12 inch panel to set it beside the BC2 to create a kind of BS5 idea. That's the goal.
  • 10-06-2009 2:15 PM In reply to
    Thank you for your respons! I will seriously look at this.
    But I'm having another issue. My 12 inch panel has a resolution of 800x600.
    If you're using beoplayer/beoport within this setting, albumcovers are not displayed in the info section. Bummer.
