Latest post 10-04-2009 3:02 PM by joeyboygolf. 4 replies.
Page 1 of 1 (5 items)
  • 10-04-2009 12:58 PM
    • boomer
    • Not Ranked
    • Joined on 10-04-2009
    • Posts 2
    Pin Number beo 3200
    Hello i am a newbie, and a novice
    just unboxed my beosound 3200 after 4 years in storage, and it asks for a pin
    all i get from the dipaly is WAIT
    any help out there on a sunday evening?
  • 10-04-2009 1:15 PM In reply to
    Re: Pin Number beo 3200
    Do as you are told, leave it plugged in and eventually the display will read PIN?
    Then enter the PIN that you used when you originally installed the 3200.
    Regards Graham
  • 10-04-2009 1:21 PM In reply to
    • boomer
    • Not Ranked
    • Posts 2
    thanks joeyboy, but i cannot remember the pin from 4 years ago, any other way or is it contact the dealer monday?
  • 10-04-2009 1:42 PM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Contact the dealer. There's no other way (that's why it was made).
    He will ask for proof of purchase so bring that along.
  • 10-04-2009 3:02 PM In reply to
    When you find the PIN I suggest that you look in the instruction manual for details of how you disable it!!
    It will inevitably cause you trouble in the future.
    Regards Graham
