I have two converters for the mac mini, 1> Mini dvi - to DVI-D, 2> Mini dvi to VGA. My problem lays in the situation as it is impossible to fund a dvi cable from a DVI-D converter of the apple to DVI-I input at the back of the BV7 and if i use option 2: i have used a vga cable to connect from the convrter of (mini dvi to VGA) and hooked it BV7at the vga socket.
Now the VGA as i have mentioned earlier post, is only used for projector purpose as the customer service people themselves have said it.
I have still made sure i had the PC on display of my beo remote and the vga cable connected to the BV7, but it just turns on with with out a pc display.
I hope you have understood my problem... thanks alot for all the effort till now mate..
