Latest post 10-04-2009 1:24 PM by chartz. 8 replies.
Page 1 of 1 (9 items)
  • 10-04-2009 4:56 AM
    Which one ot choose / Laquelle choisir
    Bonjour, Hi yall!
    Serait-il possbile d'obtenir vos conseils pour choisir une platine tourne-disque à bras tangentiel. De nombreuses choses sont dites dans le forum, mais j'essaie d'avoir une synthèse. Alors durabilité de fabrication/construction, disponibilité des stylus, qualité du son, design. Tout conseil sera grandement apprécié.
    Would it be possbile to obtain your expert advices to help choose a tangential arm (drive) Beogram deck. I've read a bit about the diffent models troughout the years but I need to come to a conclusion leading to a purchase now. So durability, stylus availability quality of desing, sound quality. Your input will be greatly appreciated.
    Alain-Olivier
    Montréal
    Filed under:
  • 10-04-2009 6:54 AM In reply to
    • Medogsfat
    • Top 10 Contributor
    • Joined on 02-21-2007
    • Posts 4,045
    Re: Which one ot choose / Laquelle choisir
    Hi Alain,
                 Much will depend on how you plan to use it. IE:- what are you hoping to connect it to and is remote control necessary? A little more detailed information will get you the answer you need.Smile
    Chris.
  • 10-04-2009 7:23 AM In reply to
    In essence there are three different types:
    1. Beogram 4000 - (or 4002/4004/6000) These are the best made decks and I think they are the best looking - not remote control unless you get a 4004 and 2400 Beomaster but you have to get up to clean the record anyway! Very easy to take apart and the later 4002 and 4004 are not too difficult to service. - My choice - the later 4004 as it is the one most likely to work!
    2. Beogram 8000/8002. Less well made but should have better performance (but from experience possibly not.) A number of service issues - difficult to take apart but Dillen now makes the tacho disc so early 8000s are not the write offs they used to be. The 6002 is not the same - more like a 4002 but less well made.These do offer datalink and the 8000 offered a brush to clean the stylus automatically - most people remove this the first time they see it in operation! Laughing
    3. Beogram 3000/5500/4500/7000 etc. These are all exactly the same and are lightweight. Pretty reliable but lots of cheap plastic in the construction. They do offer full datalink.
    As far as cartridges are cooncerned, this is the one area where things have got better. Soundsmith cartridges offer modern sound at a price and Axel can retip any sort of B&O cartridge.
    So to summarise, as far as Tangential tracking decks are concerned:
    Best sounding - Beogram 4000 - but not that easy to get working
    Most reliable - Beogram 5500 etc - Remote control but not as good a sound.
    Best design - that is your call - I think the 4000 but you may think different.
    The advantage of the 8000/8002 is that if you get a Soundsmith cartridge, you cannot see it!
  • 10-04-2009 7:57 AM In reply to
    Thanks for answering Chris,
    The Beogram would be used with a Beomaster 5000, possibly a Beosound 4.
    And also as a collectible. I just read some more in another thread, and it seems the 4000/4002/4004 are the desirable one? What do you think.
  • 10-04-2009 8:04 AM In reply to
    Thanks again for your insight Peter.
    I had read another thread and I was coming to the same conclusion on the 4000. I have my eyes on a 4002, supposedly fully functioning. Should I get it, I'd have to see how iin how good a condition it is after being shipped to me.
    Alain-Olivier
    Montréal
  • 10-04-2009 9:09 AM In reply to
    I would always recommend picking up Beograms in person. They really do not travel well and if it is working when it is sent, it won't be when it arrives. There are plenty of Beograms about so one will come up reasonably close.
  • 10-04-2009 10:59 AM In reply to
    • Medogsfat
    • Posts 4,045
    Agree 100% with Peter re:- collecting in person and also your choice of the BG400* seriesSmile
    You need to aware though that it will play directly via the Phono input of a Beomaster 5000 but will require an external RIAA preamp to use with a Beosound 4 (the Beomaster 5000 has a RIAA already fitted).
    Chris.
  • 10-04-2009 11:24 AM In reply to
    I also would prefer the 400* series to any other turntable. Not only because of superior construction and design (have in mind that the design is +35 years old!), but also because of the MMC20 series styli. In my opinion they sound way better and a lot warmer than the newer MMC 1-5 series. Construction-wise, they are much bigger and can handle more use/abuse than its newer counterparts.
    Beocenter 9300, Beogam CD50, Beocord 5500, Beomaster 3400, Beomaster 4400, 2 Beogram 4000, Beomaster 8000, 2 beogram 8002, Beovox S-75, Beovox MS150.2, Beovox RL6000, Beovox S-35, Beomaster 6000, 2 Beocord 9000, Beocord 8004, Beocord 5000, Form 1, 2x Beolink 1000, Beo4, MX3500, LS4500. Born 1993.
  • 10-04-2009 1:24 PM In reply to
    • chartz
    • Top 75 Contributor
    • Joined on 07-20-2009
    • Burgundy
    • Posts 984
    • Gold Member
    I currently own an 8000 and a 6006 (soon for sale!) and I think these are little gems. All they need is a good cartridge really. A word of warning, the MMC20EN or CL need 330pF capacitance to work properly; even then they do sound a tad dull high up, especially compared to CD. I am expecting an SMMC20EN. My preamp is a Hiraga "Le Tube" and as an amp I use an old modified Ampliton TS 3000. Along with the Beograms, the sound is gorgeous!
    I also own a Technics SL-1200 mkII/RB 300 but it doesn't sound or look anything like my beloved B&O's!
    Salut,
    Je possède une 8000 et une 6006 (bientôt à vendre !) et ces platines sont pour moi des merveilles. Elles veulent juste une bonne cellule et c'est tout. Une MMC20EN ou CL nécessitent 330 pF de charge pour fonctionner correctement, mais elles sont un peu fades dans le haut, surtout par rapport au CD. J'attends une SMMC20EN. J'utilise un préampli "Le Tube" de Jean Hiraga, et un Ampliton TS 3000 (EL 34) avec TS Millerioux. Quel beau son !
    J'ai aussi une Technics SL-1200 mkII avec Rega RB300 mais je préfère les B&O !
    Jacques
