Latest post 10-03-2009 7:44 AM by beaker. 2 replies.
Page 1 of 1 (3 items)
  • 10-02-2009 4:43 AM
    Beolab 5000 power lamp
    I would like to change the bulb in the power light on my Beolab 5000 amp. How easy is this to get at? Do you get to it from the top, bottom or front.
    Thanks,
  • 10-02-2009 6:25 AM In reply to
    • classic
    • Top 500 Contributor
    • Joined on 04-16-2007
    • Venø - Struer / Denmark
    • Posts 224
    Re: Beolab 5000 power lamp
    Beaker,
    You can get to the lamp from the top. Remove the wood cabinet. Please remember there are 3 screw's. Two screw's on the back part and one at the bottom. Then you have to remove a plast cover over the lamp.
    The lamp is an E10 socket - 60 volt lamp.
    Good luck!
    /Frede
    Beolab 5000 -  "If another amplifier sounds different then it needs repair!"
  • 10-03-2009 7:44 AM In reply to
    Many thanks Frede. I will order a bulb soon and get it fitted.
