I just repaired a Beomaster 5500 with various problems, and it is now playing nicely.
However, I had to temporarily disconnect the backup battery to clear some unknown timers. Then it of course asks me to set the clock, which I did, but each time I turn it on, it says "SET CLOCK" on the MCP. Is there some trick related to this? The radio presets I programmed stay put just fine even if I unplug the BM for a while, so the backup battery & memory should be OK.
Another thing I don't understand is that the '+' sign for "more than 14" shows on the MCP when the radio status is displayed, even though I have only a couple of presets programmed. Is there still some confusion in the NVRAM and I should keep the battery disconnected for a longer time, or is there any other way to "format" it?
It also does not talk back to my BL7000, but I guess this is a software version issue and by design?
