Latest post 09-30-2009 7:48 PM by Mr10Percent. 1 replies.
Page 1 of 1 (2 items)
  • 09-30-2009 4:30 PM
    How to activate Radio on BM5 without the BS5
    Hi
    I have just received my BM5 which is connected to my BV7-40, and it works fine (still miss the link options to the 8-32 TV in the kitchen though and the dealer had some problems installing it). But, my dealer did not know how to set up the BM5 to work with Radio instead of N.RADIO as I dont have the BS5 attached.
    I only have a BM5 and a BV7 and BV8.
    Do you have any idea?
    Thanx.
    /Leo
    BeoLeo
    Filed under: ,
  • 09-30-2009 7:48 PM In reply to
    Re: How to activate Radio on BM5 without the BS5
    Try installing Beoplayer on your editing PC, then syncronise with the BM5. This should bring up the channels.
    I think you can only use N.Radio with the BM5 only solution - unless there is something on the service menu.  I dont have this setup so cant see for myself but I think it goes something like:-
    In PC mode, (Beo4, list, PC).
    Menu, 9,  (brings up list)
    0,0,Go (makes list go into service menu mode)
    Select "Configuration" Go
    Select "Maintenance" Go
    Select "Roles" Go
    N.Muisc/CD and N.Radio/Radio selection should be in that menu.
    10%
