Hello from France
I've read a lots threads and Phil seems very skilled on B&O devices and cabling ..please Help
My DVD Avant is HS after 5 years : "Green CRT" du to a vice on Philips pro 32" CRT ??? :
The bill : 1500 €...to maintain 7000€ from 2003
1500 € is rhe price of a 50" plasma last Top Pana generation.
I decided to maintain my 2 Beolab 8000 et 2x6000 et want to connect theses 4 speakers on a Pioneer new Icepower generation.
I can't use de switch line (cinch) and connect the B&O speakers to the preamp, because I can't synchronize the 4 others speakers; with the BO
Obliged to cut off the voltage "amp out" to charge the normal powerlink and reamplify the signal internally in the 8000/6000
Need a "special BeO box" ( signal adaptator) ...again 1600€ ( 4x400€), which is more expansive than the new Pioneer 7x180W last generation !
I can't accept again such a holdup. Do you know a solution to my situation?
IF ye sor no, an answer will be highly appreciated.
Thanks in advance
Alan
