Latest post 10-03-2009 3:02 PM by Jandyt. 64 replies.
Page 2 of 3 (65 items) < Previous 1 2 3 Next >
  • 09-28-2009 1:58 PM In reply to
    • Puncher
    • Top 10 Contributor
    • Joined on 03-27-2007
    • Nr. Durham, NE England.
    • Posts 9,588
    Re: Beotime! With photo's, videos and sounds............by Andy T.
    vikinger:
    One hour + later. No more posts!
    Andy is possibly
    1.Trying to instal the batteries
    2. Is having such a good time he can't be bothered posting again,
    3. Has set an alarm time and is waiting for something to turn-on. Unfortunately he's got a long wait because he's made an error with the 12/24 hour time
    4. He's gone shopping or giving someone a driving lesson
    Let's hope he's not trying to get his Airport Express hooked up - he may never come back to finish this thread!Devil
  • 09-28-2009 7:45 PM In reply to
    Jandyt:
    Un Zauberflöte!!Big Smile
    Yes !
    very magical :)
    First B&O (1976) was a Beogram 1500 ... latest (2011) change has been to couple the BL11 with the BL6Ks *sounds superb*
  • 09-29-2009 4:36 AM In reply to
    • Jandyt
    • Joined on 04-01-2007
    • Clitheroe, Lancashire, UK
    • Posts 13,004
    More this afternoon guys, just a bit busy at the mo.
    Poor me, never win owt!
  • 09-29-2009 7:03 AM In reply to
    • Dillen
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    I thought he fell asleep...
    Great thread, Andy !
  • 09-29-2009 8:59 AM In reply to
    • Jandyt
    • Posts 13,004
    Thanks Martin.
    Now, time to put the batteries in.
    This thin rectangular piece has two little knobby bits on the end, which you have to engage in the black cap on the end of the Beotime, to unscrew the cap.
    To me, this just feels a little bit tacky, though they have thought to put a sliver of steel in the back of the tool. This will facilitate it sticking to the magnet on the wall bracket.
    I still think they will get lost or broken easily.
  • 09-29-2009 9:07 AM In reply to
    • Jandyt
    • Posts 13,004
    Then unscrew the cap.
    Looking inside, there is a black plastic 'sledge' to place the batteries in. You can't get this out by sticking your pinky in, so it will have to come out using enertia.
    Don't  flick it out vigourously, as it will fly across the room, ricochet off three walls, and end up embedded in someones eye socket.
    Instead, tap the Beotime into the palm of your hand a few times. This will bring the 'sledge' to the end of the tube, then a couple of small flicks will make it emerge from the end by a couple of thou'. You can then withdraw it.
  • 09-29-2009 9:11 AM In reply to
    • Stonk
    • Top 50 Contributor
    • Joined on 04-16-2007
    • Marlow, Bucks, UK
    • Posts 1,688
    Jandyt:
    I believe that's the exact wording taken from the instruction booklet which you didn't readLaughing Also explains why the picture is blurry
    If you think nobody cares, try missing a couple of payments.
  • 09-29-2009 9:12 AM In reply to
    • Jandyt
    • Posts 13,004
    Here is the 'sledge' or tobogan. Very flimsy, and strangely containing the serial number. (Easily swappable in the future, by unscrupulous eBay sellers!)
    Try not to sit on this, it will break.
  • 09-29-2009 9:14 AM In reply to
    • Jandyt
    • Posts 13,004
    Stonk:
    Jandyt:
    I believe that's the exact wording taken from the instruction bookletLaughing
    Is it? Gosh, and I haven't even looked at the booklet yet!  Uncanny!
  • 09-29-2009 9:20 AM In reply to
    • Jandyt
    • Posts 13,004
    Whilst the battery sled was out, I had a peep inside with a flash light. There didn't apper to be any method of opening it for repair, nor did there seem to be any shiny brass 'flash' points where dealers could upgrade in the future. There is at least one issue that needs addressing later, and I was expecting it to be done by dealers. More of that later.
    Pop three 1.5v batteries in the sled.
    The polarity is shown on the outside of the sled.
    Sorry for the blurry picture, I was getting excited.
  • 09-29-2009 9:25 AM In reply to
    • Jandyt
    • Posts 13,004
    Then slide the sled into Beotime.
    It will stop proud by a satisfyingly strong spring, then you can shove it in further and screw on the cap. I was a bit nervous about overtightening, as I didn't want to snap the two knobby things off the flimsy tool.
  • 09-29-2009 9:28 AM In reply to
    • Jandyt
    • Posts 13,004
    Voila!
  • 09-29-2009 9:30 AM In reply to
    • Jandyt
    • Posts 13,004
    Much better balanced now!  (Maglite syndrome)
    Got to nip out and take my car for its MOT. Back in a bit.
  • 09-29-2009 10:31 AM In reply to
    • Jandyt
    • Posts 13,004
    Now looking from this view, all the three display screens look the same, but they are not.  I had wondered where the Infra-Red LEDs where, and they are behind the third display.
    You can see them in action HERE.
  • 09-29-2009 10:40 AM In reply to
    • Jandyt
    • Posts 13,004
    Although the screens are small, they are easy to read. Quite pleasing to watch the numbers scrolling.
  • 09-29-2009 10:44 AM In reply to
    • Jandyt
    • Posts 13,004
    Hold down the control longer and the scrolling goes fast
    Looks like this in the dark, with a blueish backlight that comes on with movement or any keypress.
  • 09-29-2009 10:51 AM In reply to
    • Jandyt
    • Posts 13,004
    In my bedroom, I don't have a Beomaster which is remote controllable, so I have been using its built-in alarm. You set it like this, by pushing in a small trumpet shaped end piece, which springs out when set.
  • 09-29-2009 11:04 AM In reply to
    • Jandyt
    • Posts 13,004
    As you know, the Beotime can be used left or right handed. This shows how the dighits turn up-side-down when rotated,
    Looks great on my bed side cabinet!
  • 09-29-2009 12:00 PM In reply to
    Jandyt:
    Cleverly hidden, it keeps the design clean. I wonder how this will influence the range...
  • 09-29-2009 12:10 PM In reply to
    • Jandyt
    • Posts 13,004
    It appears to be slightly less range as a Beo4.
    I can turn my lights on and off through a patterned glass door between my Lounge and Dining room whilst seated in the kitchen, using Beo4, but not with Beotime.
    Due to reflections off the shiny aluminium, it seems to emanate at all angles.
    Looks good on my PC desk.
  • 09-29-2009 12:19 PM In reply to
    • Jandyt
    • Posts 13,004
    The numbers appear to slide from one screen to the next.
    Strangely, B&O have adopted a  very poor picture of a speaker driver, with a + or- sign for the volume.
    I think  VOL^ or VOL↑ would have looked better.
  • 09-29-2009 12:27 PM In reply to
    • Jandyt
    • Posts 13,004
    When you press the centre of the control pad for a prolonged press, it gives you a 'Hard Off', turning off all equipment like a Beo4, but continue pressing, and it turns lights off as well.
    This is visible by two bars that lengthen on the bttom of two of the display screens
    Two seperate functions, as can be seen here.
  • 09-29-2009 12:29 PM In reply to
    • Jandyt
    • Posts 13,004
    Anybody want to hear the alarm?
    Filed under:
  • 09-29-2009 12:36 PM In reply to
    1. those displays are far too small especially when you're half awake and bleary eyed in the morning.
    2. do the display panels light up?
  • 09-29-2009 12:38 PM In reply to
    Jandyt:
    Yes please!
    Just returned to this thread to find that Andy has spent the last 24 hours making 50 Youtube videos!
    I used to be indecisive, now I'm not so sure. [W C Fields]
