Latest post 10-07-2009 4:21 AM by Vandelay. 5 replies.
Page 1 of 1 (6 items)
  • 09-27-2009 1:56 PM
    Beocenter 9000 cd-panel failure
    The sliding panel on my bc:s cd-side doesn´t close completely anymore. The servomotor runs nicely ,but the door gets stuck in about 4/5 closed. Also the closing isn´t so smooth anymore.
    If anyone has had a similar problem please advice me what has to be done to fix it.
    Thanks!
  • 09-28-2009 2:14 AM In reply to
    Re: Beocenter 9000 cd-panel failure
    Hi
    I had the same problem with my 9300.
    Change the two drive belts cost about 2$, and clean the slide rail.
    Reto
  • 09-28-2009 3:00 AM In reply to
    Thanks Reto!
    Where can I buy the belts?
  • 09-28-2009 3:25 AM In reply to
    Thanks Reto!
  • 09-30-2009 2:05 PM In reply to
    • BegBeo
    • Not Ranked
    • Joined on 04-23-2008
    • Stockholm - Sweden
    • Posts 60
    • Gold Member
    You can buy the belts här: www.blservice.se
    Rgards Jan
  • 10-07-2009 4:21 AM In reply to
    Tack så mycket Jan
