Latest post 06-10-2007 11:22 PM by auric. 3 replies.
Page 1 of 1 (4 items)
  • 06-09-2007 1:44 PM
    Any experience with CDM - 4/33 pickup?
    Hi:
    I was given a non-functioning CDM - 4/33 pickup that I'd like to fix. Does anybody have experience repairing these units? It came out of a BC 9500.
    From visual inspection resistors 3107 and 3108 are burned. The service manual states that these are to be replaced with identical components. 4.7 ohm 2% 1/3 resistors. Does anybody know what these resistors do and what is so special about them? Would 4.7 ohm 1% of a quarter watt work also?
    Thanks,
    Derek
  • 06-09-2007 4:29 PM In reply to
    Re: Any experience with CDM - 4/33 pickup?
    These components are associated with the 5v supply. I have never seen a fault of this kind in this area so cannot be of much help.
    I suggest you contact Tim Jarman at www.beocentral.com who will at least understand the circuit and may be able to fix it for you.
    Regards Graham
  • 06-10-2007 3:18 AM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Sounds like resistors used as fuses.
  • 06-10-2007 11:22 PM In reply to
    Graham, Martin:
    Thank you for your replies.
    I corresponded with Tim Jarman over at Beocentral; they are indeed resistor fuses.
    Any ideas where they can be purchased? I'm having a hard time finding that exact value.
    Tim suggested finding a dead pickup and salvaging the resistors from there. Does anyone have a dead CDM 4/33?
    Thanks,
    Derek
