my DVD1 had problems where the DVDs kept skipping and freezing.
i opened the case.
the lens was foggy with dust!
got a cotton bud for cleanign your ears (clean one) and used some isopropyl alcohol that you can buy from chemist or a hifi shop. alterntaively the sterile wipes do the same trick.
try that.
my DVD1 works beautifully.
