Dear all,
I´ve got a used Beosound 3200 and linked it to 2 new BL3 Speakers. The speakers are working - used them with a Pioneer receiver before (on the Pre-Out). The BS 3200 switches the BL3 on (light turns to green) and a very silent noise comes from the speakers, but no music. Volume is set to 30 and also tried with 40 already. PIN Code was correctly entered and is now switched off.
I do not know in which setup it was running before, but think it was a stand alone Music system (with BL8000).
Hope you here in the forum have any good ideas...
Thanks and best regards,
Heribert
BeoVision 8-40 / BeoVision 8-32 / Beovision 6-26 / BeoSound 3200 / BeoSound 1 / BeoLab 3 / Beolab 6000 / Beolab 2000 / Beoport / Beomedia 1 / 3* Beo4 /BeoCom 5 with VOIP
