Latest post 06-09-2007 2:30 PM by Coolskin. 3 replies.
Page 1 of 1 (4 items)
  • 06-09-2007 9:01 AM
    Mac mini > BV7-40
    hello there,
    just want to check if what i need to connect and access Mac nini through "PC" is:
    - Dvi cable from the mini to the bv7-40
    - mini-jack optical toslink optical to the bv7-40
    TIA.
    Pedro "Less is more"
    BV7-40 MKII + BL7.2 + BL9 + BL3 + BS4 + BL4 + A9 + Earset 2 + 2 x Beo4 + BeoCom 5
    Filed under: ,
  • 06-09-2007 10:40 AM In reply to
    Re: Mac mini > BV7-40
    Check Coolskin here for information on what cable to use. He has a Mini connected to a BV 7-40, and it took him some time to get it connected right without the black bar on the side. Turned out it was related to the choice of cable. If I remember correctly he used a 24-pin DVI cable in the end. http://www.superwarehouse.com/Belkin_10-Foot_24-Pin_DVI-D_Video_Cable/F2E4141B10-SD/p/36451
    I think you'll need a TOSLINK Optical to Coaxial S/PDIF converter to connect the digital signal to the BV7. As far as I know it doesn't accept a TOSLINK Optical signal directly; you'll still need the TOSLINK Minijack Optical to TOSLINK connector to connect to your converter -- and then a 75Ohm digital coaxial cable from the converter to one of the coax digital connectors on the TV.
    However - ask here whether anyone has experience with the BV7 decoding surround information from the Mini correctly, and whether that requires a specific setup.
  • 06-09-2007 12:04 PM In reply to
    soundproof:
    thanks m8,
    i've sent him a pm.
    waiting...
  • 06-09-2007 2:30 PM In reply to
    PM arrived. Reply sent.
