Latest post 09-22-2009 6:35 AM by devilla. 0 replies.
Page 1 of 1 (1 items)
  • 09-22-2009 6:35 AM
    BeoVision 7-40 MKIV not changing format?
    Hi all,
    I recently acquired a BV7 and noticed that it does not change automatically to Zoom (Format 2) when needed. I just compared this with the dealers MKIII and it does change to Format 2 when there are black spaces on top and bottom. My BV7 does recognize the 16:9 (Format 3) and switches automatically.
    I am only using Digital TV signal... it could be that the new HD tuner is not programed properly.
    Blu-Ray, AppleTV and other sources are properly set by the BV7.
    Does anybody know if this is normal, will there be a firmware update soon to correct the problem?
    Thanks,
    D.
