Hi there
My old MX 6000 has lately developed a bad habbit, it turns the picture off for half a second after beeing on for an hour or so, at the same time, it says the same low sound as when it is turned on. Is it a problem with the high tension and will it be worse in the future?
best regards
Christian
Beosound Ouverture, Beocenter 9000, Beovision MX6000, Beocord VX7000
