Latest post 09-21-2009 2:41 PM by Stan. 6 replies.
Page 1 of 1 (7 items)
  • 09-21-2009 7:48 AM
    Noise from Beolab 3
    Is it supposed to come a high frequency sound from the beolabs? The sound is really annoying, especially at low volums.
  • 09-21-2009 8:04 AM In reply to
    Re: Noise from Beolab 3
    Are you using the MK3 cables?
  • 09-21-2009 8:05 AM In reply to
    I've owned Beolab 3's for a while now, and I've certainly never heard it...
  • 09-21-2009 8:12 AM In reply to
    umm, anything that has changed recently? Bought anything new that *might* affect it?
  • 09-21-2009 8:18 AM In reply to
    No, they are new. I will try to change the cables when I get home, might be a problem with the old cables. I just used some cables I found on the addict, guess they were homemade.... I will post when I have tried the original cables...And another thing, is there different MK versions of Beolab 3, and How can you see if the cables are MKI, MKII or MKIII?
  • 09-21-2009 1:03 PM In reply to
    • Michael
    • Top 200 Contributor
    • Joined on 05-23-2007
    • Atlanta, USA
    • Posts 318
    The times I've had hum or noises coming from B&O speakers it was usually cable related.  Let us know what you find.
    -Michael
  • 09-21-2009 2:41 PM In reply to
    • Stan
    • Top 150 Contributor
    • Joined on 04-17-2007
    • Posts 593
    • Gold Member
    I believe the MKIII PowerLink was developed specifically because the ICE amps are sensitive to some types of inteference that A/B amps are not.  MKIII are recommended for all ICE powered speakers.  MKIII are thin with a small triangle on the connector.
    Stan
