Television fires are usually caused by accumulation of dust and overheating. But anyway you should get it repaired sooner than later - if nothing else, for the safety of the set itself. Now it could be a matter of redoing some solderings and replacing a few caps, but if the fault goes on long enough it can cause wider damage, including charred PCBs which will make repairs difficult.
