Latest post 06-09-2007 10:53 PM by Beo. 3 replies.
Page 1 of 1 (4 items)
  • 06-09-2007 12:34 AM
    • Beo
    • Top 500 Contributor
    • Joined on 04-17-2007
    • Posts 108
    optimization of sound quality of beosound 3
    Dear all,
    I feel the sound quality of beosound 3 in mp3 area is not satisfactory. I have tried to use 224 highest VBR or even mp3 320kbps, both encoded by itunes. But I feel the sound quality is not that outstanding.
     Is there anyway to improve the sound quality further? e.g. encoded by beoplayer or use wma??
    thank you all of you
  • 06-09-2007 3:05 AM In reply to
    Re: optimization of sound quality of beosound 3
    What you are hearing are the normal limitations of a mono loudspeaker in a unit that is intended for background listening. Increasing the bitrate won't improve things.
    To my ears, the BeoSound 3 has a good sound, for those occasions where I want to have something playing in the background. I use it for audio books, for which it is absolutely perfect.
    You may consider the surface it is standing on - a wood cabinet will resonate, adding depth perception to the sound. Don't aim it at glass surfaces or other hard surfaces - and that's it.
  • 06-09-2007 2:14 PM In reply to
    • Stan
    • Top 150 Contributor
    • Posts 593
    • Gold Member
    Also remember that the speaker is toward the bottom of the unit so keep that area clear from clutter.
    Stan
  • 06-09-2007 10:53 PM In reply to
    • Beo
    • Posts 108
    thank you soundproof and stan. Actually I am putting it on wood surface always.
    maybe it is the limit of mp3
