1st March February 2012
Latest post 09-19-2009 1:21 PM by rgs218. 9 replies.
09-18-2009 7:25 AM
Die_Bogener
- Joined on 04-16-2007
- Bogen, Germany
- Posts 1,010
Quite normal after this time... defect electrolyth caps. Change the caps on the upper mainboard around the black substrate chip. Will help some weeks.
Or better: replace all of them... there are just around 150 of them in a VX7000. They all need replacement...
Have done dozens of these VX models, it's always the same defect. Caps
Die_Bogener
- Bogen, Germany
- Posts 1,010
What looks like a dirty video head is 99% a defect cap in the video line. Beleave it, i had just enough of these VX for repair. Especially the VX7000 simulates a dirty video head. After the cleaning attack of the user, you can be sure that he will need a new video head ...100%, they will not survive.
Last year i took a brand new and sealed VX5000 out of the box. It played around 4 hours, then it was defect. Some caps were exploded during this procedure... 20 years brand new, gone in 4 hours.
Caps have a time problem. They dont last forever. 10-15 years is the lifetime, then they start to leak and make shortcuts or they become simply dead.
If you want it repaired... look here.
http://forum.beoworld.org/forums/p/24191/182188.aspx#182188
Kokomo
- Joined on 08-21-2007
- Spain
- Posts 618
rgs218:
You may have a point, I do rarely use it or the VCR in my lounge now. But then I do still have a lot of video tapes that I will want to watch sometimes, plus most importantly IMO the VX looks really good underneath the MX so it would be a shame not to have it there! If there is a big problem with it they're so cheap now I'll probably just buy another one rather than fixing it, and hope the next one lasts a bit longer!
Do these problems often just appear over night? Like I said it was working excellently one day, then the next time I use it, no picture at all (but perfect sound), i.e. no gradual deterioration in quality. I had hoped it may have just been something like the settings needing to be adjusted after it had been sitting for a while, or is that not possible?
Copy all your tapes to DVD (in my case, as my VX had broken, I had to borrow one). They're probably, in the long term, much safer preserved in this format than on tape. Having said that though, I was surprised how few, if any, times I actually wanted to watch these DVDs when I copied about 40 tapes to DVD!
If you like the look of the VX in your setup, then keep it there for the time being, purely for cosmetic reasons.
Get a PVR.
tournedos
- Joined on 12-08-2007
- Finland
- Posts 5,808
kokomo:
That's what I have done - my white MX6000 on the motor stand just would not look complete without the white VX5000 under it. Actually it works - however, it is clumsy to use with the later MX one-way software, eats a lot of power even on standby, and I can't remember the last time I really watched a single tape, so it sits there unconnected.
Actually, I do remember - it was right after I managed to fix the VX (thanks again, Die_Bogener ). I watched the great concert film The Last Waltz I had recorded on the single time it aired in Finnish TV, on the new year's eve of 1983 I think. The quality was still surprisingly good, so tapes can last a long time as well if you don't mishandle them in storage. Or get a bad blank tape to begin with, that can happen...
Page 1 of 1 (10 items)
