I strongly recommend the 1202 turntable with an SP12 cartridge. It will be about half the price of the linear tables and my ears can't tell the difference between my 1202 and SP12 cartridge versus my 4002 with MCL20 cartridge. The 1202 is also less likely to be damaged in shipping. Just give the seller the usual precautions - remove platter and pack underneath the turntable; tighten locking screws under the platter; tape the arm down to the deck (not with the cartridge on it!).
Austin
Also, there's no pop and crackle on my 1202. To give you an idea, I was playing a record quite loudly for my cousins, who are both professional musicians. I mentioned the "record" I was playing and they stopped and said "wait, you mean this is a vinyl that we're listing to?" Then they both walked over and leaned down to stare at the turntable :-P
