Latest post 12-05-2009 6:19 AM by YannChris. 9 replies.
Page 1 of 1 (10 items)
  • 09-13-2009 1:52 PM
    ps3 for beovision 9
    is someone who has used this product?
    RE·BL - Infrared to Bluetooth converter   ,working properly?
    currently use nyko .
    Thanks a lot .
  • 09-14-2009 10:22 AM In reply to
    Re: ps3 for beovision 9
  • 09-17-2009 9:43 AM In reply to
    • nino
    • Not Ranked
    • Joined on 06-25-2009
    • Posts 4
    It works great, you just need to have the rebl on your STB list.
    Once it's paired with the PS3 it just works flawlessly.
  • 09-17-2009 1:27 PM In reply to
    • Toubro
    • Top 200 Contributor
    • Joined on 04-16-2007
    • Copenhagen, Denmark
    • Posts 263
    nino:
    Have you ordered yours from their website?? Because in the users guide they say that you need to use the accompanying IR transmitter cable, but in the webshop it doesn't look like such cable is supplied.
    Is it a B&O cable or a RE BL cable??
  • 09-17-2009 2:08 PM In reply to
    Thanks a lot ..
    I have decided to change nyko for RE-BL
  • 09-18-2009 3:34 AM In reply to
    • nino
    • Not Ranked
    • Posts 4
    The cable that is referred to is the B&O IR emitter cable that came with your TV. It is attached to the front of the REBL.
    I got it from my local B&O store. But you can also order it online, if you have the B&O cable.
  • 09-18-2009 3:39 AM In reply to
    • Toubro
    • Posts 263
    nino:
    Thanks. I didn't get an IR cable with my old Avant, but it's nice to know what I need and where to get it Smile
  • 09-21-2009 3:39 AM In reply to
    • nino
    • Not Ranked
    • Posts 4
    No problem, i hope you will be just as happy as me for this solution.
  • 09-28-2009 7:43 AM In reply to
    • Toubro
    • Posts 263
    Sad I wanted to go on with my plans the other day, and I noticed that my Avant, which I thought was king of 'em all back in the day when I bought it, does not have an IR port. The port hole is labeled, but there is no hardware, the plastic just covers up the hole, where it should be.
    I am a bit sad by this, but I guess I'll have to wait until I've saved up enough money for my big love, the BV9.
  • 12-05-2009 6:19 AM In reply to
    • YannChris
    • Larmor-Plage, France
    • Posts 276
    Hello!
    May you please tell me which STB you use with RE-BL?
    I'm with my dealer's tech and this device is not listed in the IT-Table generator.
    I added PS3 and Sony NS975V in my STB List (PS3 works wuuth my Nyko transmitter), but I'd liked to be sure I don't miss something.
    Thanks by advance,
    Yann.
    Ne pas s'en faire et boire frais!
    Mon install en images: cliquez sur mon profil, au dessus de mon avatar - Puis "My files" tout en bas.
    Pictures of my setup: click on my nickname, above my avatar. Then "my files" at the bottom of the page.
