rnorskov:
The anti-reflex coating came off (in patches, in one corner) due to enthusiastic cleaning - so I'm now replacing the contrast screen.
I want to replace mine as well.
Do you know what the price of a new BV7-40 contrast screen is? Or can it be replaced under warranty?
I wanted to clean some fingerprints and a piece of the coating came off. (I used a dry cloth)
The anti-reflex coating came off on the left corner at the bottom.
