Latest post 09-17-2009 11:01 AM by BeoDoc. 5 replies.
Page 1 of 1 (6 items)
  • 09-13-2009 7:40 AM
    Resetting Beocom Base?
    Help please,
    I am trying to reset my Beocom 6000 Base back to factory settings (no worries of losing any data). I did find a post instructing to press 9#9#9* INT   but I am not sure what "INT" stands for, since I can't find any buttons for it.
    Thanks.
    Beodoc
  • 09-13-2009 10:41 PM In reply to
    • Stan
    • Top 150 Contributor
    • Joined on 04-17-2007
    • Posts 593
    • Gold Member
    Re: Resetting Beocom Base?
    INT = Intercom (at least on my Beocom 1... which I always thought was the same as a Beocom 6000)
  • 09-14-2009 8:20 AM In reply to
    I thought so but didn't find it in a hurry. I will check it out tonight.
    Thanks.
  • 09-14-2009 8:45 PM In reply to
    I am trying to reset my base as well but I keep getting that I have too many handset registered to the base.  How do I clear the base?????
    THANX
  • 09-15-2009 9:32 PM In reply to
    the command 9#9#9* INT doesn't do anything. Is this the correct sequence to fully reset the base?
  • 09-17-2009 11:01 AM In reply to
    the correct code to reset the base to factory settings is:
    Dot 70008 and then press enter (thanks to Beo Care center)
    Beodoc
