Latest post 09-11-2009 10:51 PM by burantek. 2 replies.
Page 1 of 1 (3 items)
  • 09-11-2009 12:44 PM
    beotalk 1200 can not get to pick up .
    Hi
    I have just purchased a beotalk 1200 answer phone. I have followed instruction from manual and recorded my answerphone message. Listened to the message I have left ,all ok. Set the time for pick up after say 10 sec and made sure it is on. However it is not picking up so the phone just rings and rings ahhhhhhhhhhhhh.
    Please can anyone help???Hmm
  • 09-11-2009 3:30 PM In reply to
    Re: beotalk 1200 can not get to pick up .
    speedway:
    Hi
    Have you plugged the beotalk into the primary/incoming telephone connection using the B&O splitter? You will find that the beotalk will not pick-up the calls correctly if plugged into a secondary/ extension phone socket, nor will it work correctly if you haven't used the B&O splitter (or haven't copied the wiring/ pin connections with a non B&O splitter).
    Graham
    Oh, I forgot. A big welcome to Beoworld Speedway!Smile
    I used to be indecisive, now I'm not so sure. [W C Fields]
  • 09-11-2009 10:51 PM In reply to
    vikinger:
    That is where my $ lies... if you are using non original lines, confirm that your pinouts are correct!
    • B&o bottle opener
