Just hooked up my beogram 2000. Im having issues with the arm I think. If I turn it on it will track to the beginning of the record for a second or two then lift up and return to the right. It was tracking fine at first and then it would not play well on one of my LP's "loop" so I slightly adjusted the numbered weight. I then had problems with the arm. it can tilt slightly to the left or right. Im thinking one of the adjustment screws is loose, It moved slightly at the base right before the dial. I looked for service manuals but the one I found for a 2000 did not look like my LP player. it has three small buttons on the lower right, 45,35,45 and repeate. If I start the player and then slightly move the arm to a track I can get music and it sounds fine, but as soon as I press stop it does the same thing over again. Is there are info on checking and adjusting the arm.
