hi all,
steve is back and he announced some fun stuff, notably itunes 9. who will dare install it and see what happens to bm-link ?
scott
I updated my iTunes to V9.
Works fine for me. The limitations described in thread http://forum.beoworld.org/forums/t/27370.aspx persist. It is not possible to switch between playlists using Blue + << or Blue + >>. This makes BMLink hang and I have to reboot the Mac. This is not tragic to me as I mostly use the Remote.App on my iPhone or iPod the control iTunes.
I have installed iTunes on a XServer with OSX Leopard Server 10.5.8
Hi Scott,
I've upgraded to iTunes 9 and BM-Link's working fine.
Best
Rob
BV7-32, BL8000, BL2, BL6000, Humax, AppleTV3, MX4200, V8000, Humax, BS3200, BL6000, BL4000, BeoPort, MacMini+DACmagic
Any other experiences with iTunes 9?
Beosound 1, 5, 2000, and 3000
Beotime, Beotalk, Beocoms
Razlaw:Any other experiences with iTunes 9?
I have been using iTunes 9 since its "launch day +1", and I reported on the new Genius feature in the General Forum under "iTunes Genius Mixes".
I have started using it with BM-Link these past few days and experienced no problems so far.
I do get a frequent "sharp click" (a tiny electric sounding *pop* like static) when I am showing my desktop on my BV8-32; elsewhere someone (you in fact!) suggested this is a Snow Leopard effect, and I will do some experiments this weekend as you suggest with the equaliser (which I don't believe I use): certainly it does not happen on all "screens" that I display, but iTunes 9 is one where is does happen ......
First B&O (1976) was a Beogram 1500 ... latest (2011) change has been to couple the BL11 with the BL6Ks *sounds superb*
I have now installed 9 and first impressions are that it works fine.
