        1st March February 2012
	    Latest post 09-12-2009 4:34 PM by  Razlaw. 17 replies.
								        09-07-2009 4:58 PM
									        Seanie_230
								                - Joined on 04-20-2007
								                - Milton Keynes, England
								                - Posts 962
										    Hello All
If you have an Apple TV connected in the main room and someone is watcning tv can you still access the music in a link room via masterlink?
I know if you have a audio unit connected you can but what about when its conencted to the TV.
									    Beovision 7 MKIV (Blu Ray) Beolab 9 Beolab 6000 Beo 4 Beocenter 9300 Apple TV SKY HD Optoma HD65 Projector Lintronic TT455-RT-238 Beovision 3 MKII
									        PhilLondon
								                - Joined on 04-16-2007
								                - London
								                - Posts 2,545
										    Re: Apple TV Link Question
										    Yes, you can listen or view a video source in a link room that is different from the one played in the main room.
Regading the Apple TV, some people have had problems to distribute the picture to link rooms, as Beo TVs cannot distribute HD.
									        Razlaw
								                - Joined on 04-24-2007
								                - Illinois
								                - Posts 1,770
										    I just tried it and it did work.
Beosound 1, 5, 2000, and 3000
Beotime, Beotalk, Beocoms
									        Seanie_230
								                - Posts 962
										    wicked thanks gents
its ok i wont need to distrubute the video as i have the ipod touch for picking music via the remote app and i can connect the AV cable for masterlink sound.
Thanks again
									        Razlaw
								                - Illinois
								                - Posts 1,770
										    Remember also that if you connect Apple TV to the TV by HDMI you will not get sound in the link room. Must connect the Apple TV to the TV with analog cables. We have ours connected with both HDMI and analog.
									        DGeorge
								                - Joined on 05-11-2007
								                - Kent
								                - Posts 31
										    thanks for that info, Razlaw! I bought an apple tv on saturday and spent all weekend trying to work out how to get the link room to work!
Is there any noticeable difference in sound quality between the HDMI room and analog link room, do you think?
thanks again
david
									        PhilLondon
								                - London
								                - Posts 2,545
										      Razlaw:We have ours connected with both HDMI and analog.
Were you able to connect the video in both analog and digital? How did you do?
									        Seanie_230
								                - Posts 962
										    am i correct in thinking that the main room is connected via HDMI and the link room is getting its sound via Phono Leads on AV4.
As far as i have read there is an Ehco o o o o (sorry) as HDMI (digital) takes longer to process than masterlink (analogue)
									        Razlaw
								                - Illinois
								                - Posts 1,770
										    The HDMI is for the main room as both video and Audio are needed, as well as surround sound. The analog are just for the link room. We have no video in the link room as we are in the USA and Masterlink does not support video here, only audio.I do not notice any apparent difference in quality although may be a bit difficult to determine as the main room has Beolab 9s and the link room has Beolab 6000s. The sound from the 6000s is wonderful however. I do not notice any echo between the two rooms although I have also heard there is a delay.  I have everything connected to AV3 on the BV7, HDMI and left and right audio and have it assigned to V. Mem on the Beo 4.
The only issue I am having is with the PUC. I have  Apple Remote in the PUC list. However, when I turn on another source, such as SAT or N. Music it also turns on the Apple TV and then does not turn it off always when the TV is turned off. Thus the Apple TV box is always on.
									        Seanie_230
								                - Posts 962
										    there is a new PUC out for the apple tv called Apple Remote Version 1.10a which can turn the apple tv on and off
And yes sorry i meant AV 3 as AV4 is for the internal DVD player
									        DGeorge
								                - Kent
								                - Posts 31
										    Thanks again Razlaw, it sounds as though i have the same sort of set up as you, with Lab 9's, BV 7-40 in the main room and with BL4000's in the link room. I'll grab another cable and have a play!
I couldn't find any reference to Apple on the PUC list so it looks like i need to get the guys in to do a software update
cheers
David
									        Razlaw
								                - Illinois
								                - Posts 1,770
										    The Apple TV has a learning function for the remote. It is also possible to assign some other device in the PUC menu and then have the Apple TV learn those commands. I did that before we had the PUC updated and it worked fine.
http://forum.beoworld.org/forums/p/25352/193147.aspx#193147
									        DGeorge
								                - Kent
								                - Posts 31
										    Hi guys - sorry to drag this up again but i'm having real problems trying to get my link room to work.
Apple tv is connected to BV7 via HDMI lead to HDMI port D and Av3 and assigned to VMEM on remote Everything works ok soundwise and album covers etc displayed.
I've tried connecting a cable with red and white plugs to the apple tv audio sockets and to the middle 2 plugs in the AV3 section in the back of the tv, then going to the link room and pressing AV>VMEM on the remote but no sound coming out.
Is it possible to have the HDMI cable and the other cable plugged in at the same time? Am i plugging into the wrong sockets on the back of the t.v?
Any advice would be appreciated as i think the missus might have a sense of humour failure if i spend any more time tinkering!
									        PhilLondon
								                - London
								                - Posts 2,545
										    The SCART has a Sound out and a Sound in... have you connected to the right to the right connector.
Sometimes Cinch to SCART adapters have a IN/OUT switch, have you tried both.
Can you check with another device that sound comes out of the Red/White connectors of the Apple TV?
									        DGeorge
								                - Kent
								                - Posts 31
										    thanks phil - let me have a go. The scart i'll connect to is the AV3 scart?
i assume i don't have to change any of the settings on the tv i.e AV3, VMEM, set to HDMI on the screen etc
cheers
Dave
									        Razlaw
								                - Illinois
								                - Posts 1,770
										      DGeorge:
Ours is set up exactly as you describe and works fine using the Beo 4 just as you describe. As we are in the USA we do not have scart so I don't know how that would affect it.
Could it have something to do with the BV7 settings?
Ours are as follows:  Auto Selection Yes  HDMI D  Sound Input HDMI  YPbPi NO  AV3-AV3 No, although I have no idea what the last setting means or does.
By middle two plugs, do you mean the middle of the bottom row and the middle of the second row?
									        DGeorge
								                - Kent
								                - Posts 31
										    Hi Razlaw - in the back of the BV7 it looks like there are 4 sockets above the scart lead connection in the ''AV3'' section. Looking at the panel that comes off the back of the tv, they are labelled Y,Pb,Pr,SPDIF and PUC. I put the 2 plugs in the Pb and Pr sockets.
I really appreciate the time you are taking to help me
many thanks
David
									        Razlaw
								                - Illinois
								                - Posts 1,770
										      DGeorge:
many thanks
David
I think those are the wrong sockets. I believe those are for video in connection with the Y socket. Our BV7 has Video in, Y, Pb, Pr. L In, R In, PUC and SPDIF.  I have the cables connected to L In and R In. Does your BV7 not have those as it has Scart instead?  I wonder if maybe there would be an adapter you could get to connect to the ends of the two cables and then plug them into the SPDIF or into the SCART?
        Page 1 of 1 (18 items)
