Hello!
I started working on a compatible DVD Controller.
So far I can decode all the data on PIN8 of the AV and V.TAPE on my beosystem 2.
The beosystem 2 sends about 50 commands that have a prefix of the source (DVD, V.MEM (or V.TAPE), V.AUX).
The IR learning routine can handle most IR remotes (Philips RC5, Sony SIRCS, Nec, Samsung, Panasonic).
I am also planning to convert the IR commands from the STB-C board to map them to the IR commands learned by the DVD controller.
The controller powers off the device it controlls after a configurable delay after you no longer watch that source.
The unit will also relay IR signals from the original IR eye on the beosystem to BeoPort, BeoMedia and BeoLink Active/Passive units.
The unit is on a breadboard right now but I hope to build the PCB soon.
Regards,
Andrei
