Latest post 09-12-2009 6:38 PM by Maurice . 6 replies.
Page 1 of 1 (7 items)
  • 09-04-2009 5:57 PM
    • Maurice
    • Not Ranked
    • Joined on 11-26-2007
    • United Kingdom
    • Posts 56
    • Silver Member
    beovision avant vcr 28" type 8133
    Hi  can anyone help me with a problem that i have with my avant please, the problem is that no matter howmany attempts i have made to programme the motorized stand it will not turn to position on switch on, it responds to the remote to turn ok however when i switch off the  stand rotates to a memorized position, to help out  its a type 8133 so its no spring chicken but its still one very stylish  television ! any help much apprechiated .
    Maurice
  • 09-05-2009 12:38 PM In reply to
    Re: beovision avant vcr 28" type 8133
    Hi:
    I think you experienced the same problem I did but in fact it isn't actually a problem.
    You need to put the screen into the desired off position then press 0 followed by OK/Go
    You then need to move it to where you want it when on and press 1 followed by OK/Go.
    I think, this is based on my memory of how to do it.
    Graham
  • 09-10-2009 12:56 AM In reply to
     At the setup-menu chose the 'stand', then chose 'turn tv to preferred position' - do it with the arrows on the Beo4, and press the 'go' button...
     If that does not work, your tv is somehow defekt..
    /Jesper G
  • 09-11-2009 5:01 PM In reply to
    • Maurice
    • Not Ranked
    • United Kingdom
    • Posts 56
    • Silver Member
    Hello Graham
    Thanks for taking the trouble to reply, unfortunatly it hasent resolved the problem.
    Regards Maurice
  • 09-11-2009 5:04 PM In reply to
    • Maurice
    • Not Ranked
    • United Kingdom
    • Posts 56
    • Silver Member
    Hello Jesper thanks for replying, i tried the positioning as you said , it seems ive got a problen with the pcb, but thanks anyway.
    Regards Maurice
  • 09-11-2009 11:12 PM In reply to
    This sounds like the Avant is new to you, and I don't recall reading "STORE" in this thread??? Are you storing the settings after you set them?
    • B&o bottle opener
  • 09-12-2009 6:38 PM In reply to
    • Maurice
    • Not Ranked
    • United Kingdom
    • Posts 56
    • Silver Member
    !!! YES YES YES!!!
    think ive sussed it thanks to your help ...
    regards Maurice
