I'm from Bendigo and unfortuntely dont also have the time to be with the installers so even finding the time just to be with them is going to be a pain.
I have already had them configure the settings in store including the the pioneer bluray player and is now going to be a matter of finding the time to do it and hopefully plug and play. If I cant make the beomaster 5 work with my computer, I think it is easy as I can just unplug it and bring it back to them. They have also assigned everythin in store including logos in the beo5 remote.
Now with the cables, interestingly, their cables esp the hdmi is probably the cheapest in the market in relation to the Monster Cables that are around. If you go to one of the shops here and if you're from Shep then I am pretty sure you will know that it cost about 500 to get one from Harvey Norman and they wont let you go out of the shop till you get one fo the their most expensive cable.
I am just a bit worried now that their support will be quite difficult. I am in fact considering at some point to just get a Loewe as they have local support.
Do you have any idea of any support person in Shepparton since you are just an hour away.
Voltaire
