Hi B&O guys
I recently got a pair of Beolab Penta 1 with integrated Amplifiers.
One of them went into off state (red led) while i was testing them.
so i thought i will check all connections, see if the switches are ok und when i am already at it, replace the capacitors...
i already found this thread: http://forum.beoworld.org/forums/t/5850.aspx?PageIndex=1
but maybe someone can help, where to start. should i replace all caps? including the two of the power supply? what about replacing the opamps? what makes most sense?
thanks in advance...
