Latest post 06-08-2007 12:59 PM by Kevin. 5 replies.
Page 1 of 1 (6 items)
  • 06-07-2007 4:11 PM
    • guv
    • Not Ranked
    • Joined on 06-07-2007
    • Posts 2
    avant surround sound with non b&o
    Hi everyone, new to the forums.
     I would like to connect by Avant 32 dvd, to a cyrus3 preamp/amp powering passive tdl's for my front surround speakers. few questions though,
    http://www.cyrusaudio.com/product.asp?ProductID=60&text=spec
    1 - is it possible?
    2 - is it as easy as connecting 2 rca's to 2 din's?
    3 - what are the pinouts? (12 and 3 from soldering side?)
    At the moment, I just use the 3.5mm stereo jack to connect the speakers, and I just want to upgrade this setup to surround. Havnt got the space to put beolab 1's or 8000 which is what I really want, but you cant have it all.
    Many thanks in advance.
    Guv
  • 06-07-2007 4:59 PM In reply to
    Re: avant surround sound with non b&o
    The Powerlink sockets have both left and right speaker output in each plug so you need a Powerlink to RCA adaptor. I would feed this to the power amplifier and bypass the pre-amp as you will be able to control the volume from the Avant then. The wiring diagrams are www.Beotech.co.uk .
    Best of luck!
  • 06-08-2007 1:04 AM In reply to
    • Kevin
    • Top 50 Contributor
    • Joined on 02-15-2007
    • Moderator
    • Posts 1,256
    I've found with my Avant (old 50hz) that powerlink output is not at line RCA level so volume levels are low.
  • 06-08-2007 2:47 AM In reply to
    • Puncher
    • Top 10 Contributor
    • Joined on 03-27-2007
    • Nr. Durham, NE England.
    • Posts 9,588
    Kevin:
    What you need is to build a preamp! LaughingLaughing
  • 06-08-2007 10:48 AM In reply to
    • guv
    • Not Ranked
    • Posts 2
    ok guys, thanks for the reply's, bit of an update and a further question.
    I made 2 cables, both are rca - 7pin din (fits nice in the powerlink socket) fired it all up, and it works like a dream. They act as front left and right speakers.
    I can control the volume, works fine. Im not sure if its line level or not, but if i leave the amp at 40%, all is sweet. (only a teenie bit higher than i would leave it using a cyrus cd player or my naka cassette)
     ok, if i wanted to add rear speakers, what would the pinouts be? would they be the same? i cant find the pinouts that are specifically for rear speakers
  • 06-08-2007 12:59 PM In reply to
    • Kevin
    • Moderator
    • Posts 1,256
    Puncher:
    Kevin:
    LaughingLaughing
    I know ,I know... unfortunately the priority has been pouring (and paying for) concrete on which to put the kids pool..... 32 degrees here so worthwhile I'm sure you'll agree.Cool
