Latest post 10-22-2009 12:34 AM by XavierItzmann. 51 replies.
Page 3 of 3 (52 items) < Previous 1 2 3
  • 10-10-2009 5:23 PM In reply to
    Re: First picture of the new BeoCom 5 ?
    burantek:
    Interestingly, I received the following pic in an email from B&o...
    Same pic as the OP, but with the phone either shopped out, or a second pic taken without it...
    I think it was shopped out after this thread started, making the OP a great spot!
    Hi Jeff,
    As another thread is now showing the Beocom 5 in the N American Catalog(ue) maybe the left hand doesn't know what the right hand is doing at B&O !
    Graham
    I used to be indecisive, now I'm not so sure. [W C Fields]
  • 10-22-2009 12:34 AM In reply to
    beoberlin:
    Is BeoLine 2 the newer, 'rounder' PSTN base (http://www.beoworld.org/prod_details.asp?pid=1235) or a totally new product? If so, is Beoline 2 compatible with BeoCom 6000 Mk II (with earset connectivity)? Would be interesting as I plan to upgrade my older, rectangular PSTN base...
    For a US customer, this is all extremely confusing.  The "English" manual available on bang-olufsen.com makes reference to a BeoLine which might indicate they refer to the US Beoline, but I suspect _not_, and refers only to the Euro-Beoline.
    Why?  Because when the manual lists handsets that are compatible with Beoline 2, it does not list Beocom 1, which is ... a two-line cordless.  It is what I have.
    My US-Beoline for Beocom 1 is a two-line box... which is not compatible at all with US-Beocom 6000 Mk1.
