Latest post 09-01-2009 2:55 PM by Eugenio Colazzo. 2 replies.
Page 1 of 1 (3 items)
  • 09-01-2009 8:53 AM
    Beovox 3702 - How to define +/-
    Hello everybody
    I'm here to ask help about the way to define the positive and negative wire of the Beovox 3702.
    Thanks in advance
    Eugenio
    Eugenio Colazzo
  • 09-01-2009 2:34 PM In reply to
    • yachadm
    • Top 100 Contributor
    • Joined on 06-24-2007
    • Jerusalem, Israel
    • Posts 687
    Re: Beovox 3702 - How to define +/-
    Disconnect the speaker from the amplifier.
    Take a 9Volt battery - touch the wires briefly to the battery.
    If the woofer jumps forward towards you, then the Positive wire is on the Positive battery terminal.
    If the woofer jumps backwards into the speaker, then the Negative wire is on the Positive battery terminal.
    Works for any speaker.
    There are other ways, but this is the simplest.
    Menahem
    Learn from the mistakes of others - you'll not live long enough to make them all yourself!
  • 09-01-2009 2:55 PM In reply to
    Yes -  thumbs up
    Thanks thank thanks!!!!
    Eugenio
    Eugenio Colazzo
