Latest post 09-01-2009 9:05 AM by majand. 6 replies.
Page 1 of 1 (7 items)
  • 08-30-2009 12:11 PM
    • murphy
    • Not Ranked
    • Joined on 08-30-2009
    • Posts 1
    Speakers make a loud 'pop' when power is switched on for BeoSound 9000
    I 'inherited' this system when I bought the property it is in so I don't really know much about it.
    When I switch the power on at the wall socket the speakers make a loud 'pop', just the once.
    It's quite loud and I'm concerned it is damaging the speakers.
    Usually I leave it on standby to avoid this but ocassionally it gets turned off at the wall socket.
    The main system has 2 X BeoLab 8000 speakers, one on either side of the system.
    It is also hooked up to 2 X Beolab 3500''s (One on the patio, one in the main bedroom) and also hooked up to 3 X BeoLab 2000's at various sites throught the house.
    The 2 main speakers are the only ones that 'pop'
    This has been the case since I moved into the property.
    There are no other issues with any of the other components and the sound is fantastic when being used.
    Any thoughts on why this could be happening?
  • 08-30-2009 12:42 PM In reply to
    Re: Speakers make a loud 'pop' when power is switched on for BeoSound 9000
    Nice system to inherit! B&O equipment is really designed to stay in stand by though clearly that does use energy (though very little with the modern equipment). If you can turn the speakers on first, that might make a difference.
  • 08-30-2009 1:07 PM In reply to
    We have a somewhat similar issue. We have an Avant with no other speakers connected to it. Recently I connected some speakers to it and when turning the system on or off a very loud pop occurs in the front speakers, but not the rear speakers. I spoke with a technician and he referred to it as a "DC pop" and knew exactly what part needs to be replaced in the Avant. I understand your pop occurs when the speakers first receive power, not when going from standby to on, but thought I would mention our similar issue.
    Beosound 1, 5, 2000, and 3000
    Beotime, Beotalk, Beocoms
  • 08-30-2009 2:48 PM In reply to
    Hi. I had that problem once when I cut powerlink cable and then taped it back together.  After I had it soldered, the problem stopped.
  • 08-30-2009 7:06 PM In reply to
    • Dave
    • Top 50 Contributor
    • Joined on 04-17-2007
    • Brisbane, Australia
    • Posts 2,328
    I used to turn my system off at the wall, but once my BL4000's power supply failed i started to leave everything on stand-by.
    Obviously the pop isn't normal, but leave it all in stand-by in future. That's what i'd do, it prolongs the life of the power supplies, and for you makes things easier without the pop.
  • 08-31-2009 4:04 AM In reply to
    • beoaus
    • Top 150 Contributor
    • Joined on 04-16-2007
    • Melbourne, Australia
    • Posts 445
    Try disconnecting the powerlink socket on the speaker you turn on.  Does it pop then, if so try a new power cable and socket to narrow down the fault?
    As you have masterlink as well you may need to check the shields in the cable.  You could try your local dealer for a masterlink and power link tester as well...
    These methods stopped the loud pops in our house. In my experience the BL8000's and BL4000's seem particularly sensitive to this problem..
    good luck beoaus
  • 09-01-2009 9:05 AM In reply to
    • majand
    • Not Ranked
    • Joined on 02-26-2008
    • Helsinki
    • Posts 72
    • Gold Member
    I have a somewhat similar problem, but with a BC9500. It's installed at countryside, where it's quite common to get brief cuts or flickering in the mains power. If I just normally plug in the socket, I get a "medium" pop. But when there is a cut or bigger flikering the pop could be quite loud. It's a surprising, and not a nice one, sound, especially on the daytime, when you don't see the flickering.
    When I'm away I tend to plug it off from wall, because the environment is also a bit lightning prone.
    So is the popping in BC9500 normal and a small UPS is needed, or is there maybe some mains caps in need for replacing?
    Pekka
    Filed under:
