Latest post 08-30-2009 4:06 AM by Peter. 6 replies.
Page 1 of 1 (7 items)
  • 08-29-2009 5:41 AM
    • BegBeo
    • Not Ranked
    • Joined on 04-23-2008
    • Stockholm - Sweden
    • Posts 60
    • Gold Member
    Beovision 5 - Has sound but no picture
    Hi I have a BeoVision 5, which starts and also has sound but no picture, plasma screen is completely black.
    Grateful for the help
    Regards
    Jan
    Filed under:
  • 08-29-2009 8:15 AM In reply to
    • Medogsfat
    • Top 10 Contributor
    • Joined on 02-21-2007
    • Posts 4,045
    Re: Beovision 5 - Has sound but no picture
    Is this a recent problem?
    Were there any signs of picture failure leading up to this?
    Chris.
  • 08-29-2009 8:43 AM In reply to
    • BegBeo
    • Not Ranked
    • Posts 60
    • Gold Member
    Hi Chris, thanks for your reply.
    It was ok last night without problem and today when I started it so the image was gone. There were no signs of a possible error.
    Regards
    Jan
  • 08-29-2009 9:27 AM In reply to
    You can now use it as a radio! :-))
    Solution: Have tried the same on BV7, although BV7 is LCD not plasma.
    Disconnected the wall plug for some 10 secs. then replugged, and the TV turned on perfectly with sound and picture.
    Try it, hope it works.
  • 08-29-2009 9:48 AM In reply to
    • BegBeo
    • Not Ranked
    • Posts 60
    • Gold Member
    It would be a cool radio :-))
    My BeoVision has an electrically powered floor stand, and I disconnected but without success to create the image.
    Regards
    Jan
  • 08-29-2009 11:02 AM In reply to
    • BegBeo
    • Not Ranked
    • Posts 60
    • Gold Member
    I would add that I yesterday took away the front frame from my BeoVision 5 to clean it.
    I started the BV5 first today so the picture was gone, I guess it does make the error but I'm not sure.
    Could this be why I now have a black screen?
    Grateful for any helpful answers.
    Problem solved, there was no wrong I just turned off the mains
    Switch to the PDP when I had removed the front frame of my BV5 to
    clean it behind the frame. The switch is hidden behind the front frame and
    when you remove the front, you can turn off the power only to the screen (PDP)
    of mistakes, I must have turned off the PDP.
    Next time I know
    Regards
    Jan
  • 08-30-2009 4:06 AM In reply to
    Well done - I have never pulled a BV5 apart but I understand that the screen is simply a Panasonic screen with all the usual controls.
