Assuming that the electrics are good (which they usually are), this entire series suffers from one MAJOR mechanical fault, which is easily repaired with patience.
Open up the BG, and look at the solenoid in the middle of the main PCB.
Carefully disassemble the solenoid, and pull out the piston inside the solenoid.
Before doing anything else, mark one end of the magnet for polarity and orientation.
You will probably find that the plastic housing, in which the magnet lays, is cracked, causing friction inside the solenoid tunnel, therefore the BG appears dead.
Discard the plastic bed in the middle, and glue the 2 plastic ends to the magnet with 24-hour, slow-set epoxy. While the glue sets, make sure that the piston is setting in an absolutely straight line.
Spray silicone-spray inside the tunnel, and wipe off the wet residue with a tissue.
Spray the magnet with the same spray, and wipe off.
Reassemble your BG, and so it will come to life!
Menahem
Learn from the mistakes of others - you'll not live long enough to make them all yourself!
