I have managed to locate the panels. Here are their condition:
Panel 1: On the plastic portion, there is a spot in the plastic next to the display window that has "clouded" over -- depending upon the viewing angle, this may or may not be visible. On the blue aluminum, there is a small scratch and small indent in the very lower left corner -- again, depending upon the viewing angle, this may or may not be visible. On the side of the blue aluminum, towards the back, there is a small noticable scratch [perhaps more like a gouge type of damage?].
Panel 2: On the plastic portion, there are some minor superficial scratches, with one being about 1/2 the length of the plastic. Perhaps another member can advise whether these scratches can be buffed out. The blue aluminum seems okay other than some sticky gunk [probably the result of being in storage for the past 5 years] which I will try to clean up and is not that visible.
Hope this helps.
