Latest post 08-27-2009 2:58 AM by Avi. 5 replies.
Page 1 of 1 (6 items)
  • 08-26-2009 9:40 AM
    • Avi
    • Not Ranked
    • Joined on 08-26-2009
    • Posts 3
    Open DVD1 to multi-region?
    So I've tried some stuff I found on the web but nothing worked.
    Anyone got any idea how I can open my DVD1 B&O to be multi-region player?
    Thanks in advance!
  • 08-26-2009 10:45 AM In reply to
    • kallasr
    • Top 75 Contributor
    • Joined on 04-19-2007
    • Willich, NRW, Germany
    • Posts 1,077
    Re: Open DVD1 to multi-region?
    My Beo: Beosound 3000, Beolab 4000, Beo 4 DVD,  Beolab 5000/Beomaster 5000, Beovox S45.2 with Stands, Beosystem 7000 black with Beolink 7000, Beolink 1000, F1000 (3 cubes), Beovox 5000, Beovox 3000, Attyca 1.
  • 08-26-2009 4:58 PM In reply to
    Its about a 5 minute job once you have the instruction list and a suitable remote control (Beo4?).
    It can take a couple of attempts to 'take' but relatively simple if you have the instructions.
    I suggest you find a tame engineer.........
    Train Hard - Run Fast - Hit to Kill!!!
  • 08-27-2009 1:03 AM In reply to
    • Avi
    • Not Ranked
    • Posts 3
    I also took it to some lab and they're having hard time finding it, they have the code but for some reason it simply doesnt work. They still managed to change zones if they tried, but the multi-zone hack simply doesn't work.
    Anyone got more ideas?
  • 08-27-2009 1:53 AM In reply to
    Avi, do you bave a B&O service centre near you? If so, take it there and they can do it on the spot for not much money.
    Good luck
    My B&O: 2009 Catalogue and Pricelist
  • 08-27-2009 2:58 AM In reply to
    • Avi
    • Not Ranked
    • Posts 3
    Ok they've fixed it!
