Latest post 08-28-2009 11:58 AM by Peter. 8 replies.
Page 1 of 1 (9 items)
  • 08-26-2009 7:35 AM
    Beovision 7
    Can anyone tell me the main differences between BV7 mk1/2/3/4? Beocentral has nothing to date and the Beoworld description has not been modified since 2007. For e.g when did the external lights change from red to white/blue?
    David
  • 08-26-2009 8:23 AM In reply to
    • Tayne
    • Not Ranked
    • Joined on 05-31-2007
    • Posts 23
    Re: Beovision 7
    The lights went from red to white when the MKIII was released. The MKIII version also introduced the BeoSystem 3 chassis. The MKIV was released as the same TV but with the addition of 100Hz screen and a built in Blu-Ray player rather than standard DVD.
    T
  • 08-26-2009 8:56 AM In reply to
    • mbee
    • Top 50 Contributor
    • Joined on 04-18-2007
    • Paris, France
    • Posts 1,133
    Re: Beovision 7
    I think that the MKI only had a DVI input, the HDMI went with the MKII. Correct me if I'm wrong!
  • 08-26-2009 9:09 AM In reply to
    Re: Beovision 7
    I hereby correct you.
    BeoVision 7 - 40 MKI - DVI+Component, red light display, HD ready, 1366x768
    BeoVision 7 - 40 MKII - DVI+Component, red light display, HD, 1366x768
    BeoVision 7 - 40 MKIII - 4x HDMI + component, white light display, Full HD, 1920 x 1080
    BeoVision 7 - 40 MKIV - 4x HDMI + component, white light display, Full HD, 1920 x 1080 , 100 Hz
    BeoVision10-46MKII,BL3,BL2,BS8,Beo5
  • 08-26-2009 10:21 AM In reply to
    Re: Beovision 7
    Thank you for that. Did the mk1/2 have the Avant chassis and connections (3XAV scart) in addition to DVI?
  • 08-26-2009 10:32 AM In reply to
    Re: Beovision 7
    BMGHB, could please you give us the same details for the BV7-32....
  • 08-28-2009 11:26 AM In reply to
    Re: Beovision 7
    BV7-32 MKI - DVI+Component - HD ready
    BV7-32 MKII - DVI+Component - HD ready
    BV7-32 MKIII - DVI+Component - HD
    BV7-32 MKIV - DVI+Component - HD - With or without DVD
    BV7-32 MKV - 2 x HDMI- HD - built in DVB-HD - With or without DVD
    As far as i remember. The MKV is the current model and has a stunning picture quality.
    I have had the MKI and MKIV and there is a BIG difference in the picture quality = better LCD panels.
  • 08-28-2009 11:28 AM In reply to
    Re: Beovision 7
    No it doesnt have the Avant chassis. I has a customised BV1/BC1/MX8000 chassis.
    Yes it has three scart plugs in addition to the DVI and component.
  • 08-28-2009 11:58 AM In reply to
    Re: Beovision 7
    If someone would like to do an up to date write up for the site, I will put it on. I am no expert on the BV7!
