Hi
I'm moving house and to cut a long story short I'm contemplating subscribing to a VirginMedia bundle. Part of that bundle will be a TV package and a V+ HD box.
My current setup is a BV3 28" with STB-C and DTS card, the front channel of which is connected to pair of BL8000s.
I see from the STB Controller list Western Europe Version 4.11 that the Virgin V+ box is listed. Is this the same as the V+ HD box?
Is anyone using this STB-C entry with a V+ HD box ? If so what do you think? Any missing functionality?
I'm well aware that my BV3 is not HD and plan to connect it to the V+ HD box via scart. However, when watching an HD broadcast with Dolby Surround Sound will I be able to benefit from the surround sound if I connect the optical out on the V+ HD box into the spare optical input on the DTS card?
Any thoughts, comments much appreciated.
