Latest post 08-26-2009 4:34 PM by Stephan. 1 replies.
Page 1 of 1 (2 items)
  • 08-24-2009 4:32 PM
    BeoSound 3 : How do I open the top to remove the control surface?
    Hello,
    I wanted to know if someone can give me some guidance regaring opening up a BeoSound 3.  It is clear that the top can be raised partially on all four sides and I can see that there is some form of tensioning mechanism which holds it in place.  Is the top released from the top someohow or do I need to open up the bottom to get to it?
    Regards,
    Greg
  • 08-26-2009 4:34 PM In reply to
    Re: BeoSound 3 : How do I open the top to remove the control surface?
    Hey greg,
    wouldn't try it, if its damaged, a replacement is below 100 Euros.
    Mine was damaged 2 times now without any signs from the outside, seems like this part tends to break
    by itself ...
    rgds
    Stephan
