Ok, so I've moved my BC 9000 to a different room (after its been unsed for a couple of months) and have tried to plug passive speakers back in.
It seems only 1 pair (the right set when looking from the front) works! The left hand side pair doesn't produce any sound using the same setup.
I vaguely remember mute will only work on the 1st pair and mute doesn't make any difference so I'm guessing the primary pair are knackered and the secondary are working fine.
Is there anything easy to check / or do or am I just stuck with only using one set of passive speakers?
Cheers
GUY
Train Hard - Run Fast - Hit to Kill!!!
