Latest post 08-26-2009 3:52 AM by simon456. 7 replies.
Page 1 of 1 (8 items)
  • 08-21-2009 4:43 AM
    Problem with Net radio :(
    Hi guys , first post !! :)
    Having lots of problems with my beosound 5 ..... can anyone help?
    The most frustrating one being interuption to the net radio play back when our beocom 6000 is in use.
    As soon as the phone rings the the audio cuts out!? any ideas guys?
    Thanks in advance
  • 08-21-2009 5:11 AM In reply to
    Re: Problem with Net radio :(
    Welcome to Beoworld.
    The problem is with your ADSL, have you installed the correct "filters" on every phone sockets?
  • 08-21-2009 5:19 AM In reply to
    Thats for the quick reply!
    I suspected that myself and have put filters on the sockets but im still having the interruptions. Any other things I can try?
  • 08-21-2009 5:22 AM In reply to
    Is your BM5 connected to your router using Wifi?
  • 08-21-2009 5:26 AM In reply to
    No its hardwired, sorry guys, should have mentioned that before
  • 08-21-2009 6:34 AM In reply to
    And does you internet connection on your computer goes down as well when the phone rings?
  • 08-22-2009 6:50 AM In reply to
    • TWG
    • Top 75 Contributor
    • Joined on 04-17-2007
    • Germany
    • Posts 950
    • Gold Member
    do you have s.th. like a crossover installed for the internet broadband connection?
    In Germany it is common that you have a little box (smaller than a cigarette box) that acts as a crossover to split the telephone and broadband signal at home.
    When this little box is broken you have nearly the same symptoms you described above.
    The exchange of this little box is free of charge when it's damaged here in Germany
  • 08-26-2009 3:52 AM In reply to
    Internet conncection seems fine , which is strange..... Its bugging me big time!
